Debra Carter 20 points N/APosted on - 09/25/2012
Hi experts,
How to convert ppt mac to flash? Give me some ways on how I will be going to perform this kind of conversion process I don’t have a clue on which website to visit to download software that will allow this to be done. I need a step by step procedure to get this all done, can you help me experts?
To convert a PPT file into flash on MAC OS, You have to do the following terms:
1. Create your Power point presentation. You should include all of your animations before saving the file. This includes transition between slides and timing of slide transitions.
2. Save the presentation with the file extension .wmf. To do this , click File > Save, and enter a file name. Immediately following the file name , add.wmf.
3. Open Adobe Flash. Create a new Flash document and set the viewing settings to 720 x 540 . Make sure to change the background color to black.
4. Import the ppt.wmf file you previously saved.
5. Save the new file by clicking File > Save. You have now successfully converted your ppt file into a Flash file.
You wanted to know how you can convert from ppt to flash on your mac os. This kind of conversion are rarely to be ignored as this helps the officials to advertise the workforce. However, this video will be a good lesson for you.
You wanted clue for downloading converter software. Here are they:
There isn't many program for mac OS that converts PPT to flash. But you can try Keynote presentation which converts PPT both in MOV and Flash and it works great. Importing from PPT is usually easy; it depends on the fonts and design. You can download another useful software from here –
A Quiet Revolution in the World of Pages
Once upon a time every book left a trail. Bent spines dust jackets that never quite sat right paperbacks split at the seams. Shelves groaned under the...
1....
