How to convert pub to gif?
Hi techyv,
How to convert pub to gif? I would like to know a website that will offer a free conversion of different variety of file formats such as gif, jpeg, pdf files and more. I also hope that it will consider the computer registry security system from malicious ware viruses.
Hoping for your help. Thanks.
Best Answer by roney184
Answered By 0 points N/A #187500
Hello marry!
Here is a solution for you.Just follow The steps and you can easily solve this problem.
And one more thing,you need Microsoft Publisher to do this task.You will find it on the Microsoft office Suite package.Okay now follow these steps.
1. First,Open Microsoft publisher to your desktop.
2. Top of the Publisher screen Click "File" tab. Browse down to " Open" and locate the .PUB file you want to open.Double click on the file.
3. File tab at the top of the Publisher screen click it. Browse down to the option "Save As". "File name" click on it and rename. "Save as type" labelled box click the arrow beside it. Choose the option titled "GIF-Graphics Interchange Format".
4. Now " SAVE " it..
okay! Hope you understand the process.For further help don't hesitate to ask me.
Thank You!
Imran Hasan
Answered By 0 points N/A #187501
Charles,
You said, you want to convert a file which has an extension name of pub or in publisher to gif of jpeg format. All you have to do is to highlight the layout then right click on the selected layout then select “Save as Picture”, then click “change”, then select “high quality printing or commercial press”, then click “ok”. Then “save”.
