How to convert RAW to JPG?
Hello Austin,
I see you ask for a program to convert a format to another, well you really can do directly on the internet without downloading a specific program just typing in google.com something like “convert x format to x format”. Once you find an online application you just have to upload the image, choose the target format, click on start and finally obtain from the link given the image already converted.
But since you want a program you could get one of the following:
Hi Austin,
It is easy to convert Raw format to JPG if you are using Adobe Photoshop CS5. 1 and following these steps
1. RAW files are camera negatives. So at first import your photo in Adobe Bridge and double click on the RAW format.
2. This file will be open in the Camera Raw window. Now you can edit as you wish with color effects.
3. Save the file and open it in Photoshop.
4. Now follow the sequence File > Scripts > Image Processor and convert as you wish.
5. After that save your image.
You can try it in other way. There are a lots of cameras can take pictures both in RAW and JPG format.
So you want to avoid formatting your images each time you may think to buy a camera like that.
That will save a lot of your time.
Hello Ashan. That was so cool.
Thank you for your help. It was very to understand.
Got my RAW converted because I got a solution from this website.
Thank you
