I need to convert real media en wma sur Mac. I want that the converting process will be easy to trim and keep my favorite video segment, adjust video effects such as contrast and brightness, add any subtitle and crop to retain focus video.
How can I make this possible?
How to convert real media en wma sur Mac ?
Hello Gracekmakris,
.RM to .WMA Converter Portable.
Best RM file to WMA converter for Apple Macintosh:
Support Convert RM files to WMA files.
Convert files between audio and audio on Mac.
Supports convert files between video and audio.
Edit RM files and save as WMA audio files on the Mac OS X system.
Preview window and batch RM to WMA sound conversion.
Free of spyware and Adware.
Lifetime free version update service.
For more information and to download check the link.
Hope this will help you.
Thank you.
I have found that “Format Factory” is awesome software for converting .RM to .WMA files. You will be amazed to know that it’s useful for converting any type of file.
You can even convert photos so that it’s like all in ONE! I believe you can use it.
Hopefully, you will enjoy it.
