How to convert RFT format files into doc format on Ubuntu Linux
Hi expert, I need a help.
How to convert RFT format files into doc format on Ubuntu Linux. Is there specific software to convert these format files?
If you know please send the download link.
And send some helping tutorial explanations for how to use that software, Special features, Main advantages and disadvantages.
Answered By 80 points N/A #167041
Hello Boby,
First it should be corrected as RTF (Rich Text Format).
You can use Open Office or Libre Office to open a RTF file in Linux but these programs will not be able to save it as a DOC.
So what you can do is use a online tool to convert the RTF file to a DOC file.
There's a website called Online converter which gives the ability to convert RTF to DOC. Click here to convert.
Zamzar is also a good website which has the same ability Click here.
