casey cock
30 points
Posted on - 05/06/2013
Hello expert, I am learning about E-commerce concept. I have to do some projects about blogs and web development. Actually I am searching about RSS feeds. I got an error in RSS feeds. So I want to know how to convert rss to text script without using any software. Please reply me as soon as possible. Thanks.
How to convert rss to text script without using any software
Hi! You can convert your RSS feed to PHP, JavaScript and html online there is a site where you can convert it effectively. Here is the site http://www.rssfeedconverter.com/
This code converter stands alone where you are allowed to even comb in some RSS feeds to a single block that you can insert into your website.
Hi Casey,
RSS feeds are an easy way of sending and receiving text but they can be boring for the simple fact that readers can not see the entire message. However, there is an online tool known as FullTextRSSFeeds that solves this problem. This tool allows you to enter the URL of a regular RSS feed and submit it. It is then converted to full text RSS feed and you will be given a URL for the new feed. This URL is the one you will use on blogs and websites. You do not need to download anything. FullTextRSSFeeds has the following features:
1. Converts Partial RSS feeds to Full Text
2. Does not require any downloading or registering
3. It is fast and free
This is the website for FullTextRSSFeeds www.fulltextrssfeed.com
Similar tools include FullFeeds and Wizardrss
