How to convert shock wave file to power point?
Hello TechyV users,
I am a computer user who has a small knowledge about it at least less than you all. My question is if I want to convert shock wave file to power point then how can I accomplish it
Best Answer by Drake Vivian
Answered By 80 points N/A #174875
Greetings FIdel P Ellis,
Yes there is a way you can import flash (.swf) files into PowerPoint. But it's pretty lengthy procedure so I can't talk about it here.
I'll give you a link to a website where you can read about it and learn how to do it.
Flash Animation to Powerpoint (click )
There is also one here on this LINK.
This one is pretty much the same but maybe it will be easier for you.
I hope this helped you,
Regards.
Answered By 30 points N/A #174876
Hi there Fidel P Ellis,
There are several ways you can convert your flash files into the power point files.
In case you'd like to completely convert the file, you should firstly convert it into a movie file with .avi extension. That can be done with any video converter.
You can also embed the flash file into your presentation via an insert option in PowerPoint.
Still the easiest way is to use some of the converters like the iSpring PowerPoint to Flash Converter
Best regards,
Drake Vivian
