I am having some issues on converting Vector to TTF format file.
And I need to know how to do this correctly.
Is there any online utility tool that I can use to perform this?
Or any program which I need to install before the conversion?
How to convert vector to ttf format?
Hello Ruthtmagnuson
You need to download and install a program for the conversion. In order to convert to TTF. Download Gimp raster graphic editing software if you are not using adobe Illustrator with which you will use to open the graphic editor. Use this and if any further questions we are at your service.
If you have an Adobe Illustrator on your PC, you can use it to convert or save a vector file into .TFF format. Just follow the steps.
Open the vector file you want to convert or create your own vector.
Select the vector file then go to Object > Rasterize > and set your rasterized setting and click OK.
Go to File > Export > type the Filename you want and choose the file type .TFF.
You can also use the Gimp raster graphics editing software if you don’t have Illustrator. Just download and install it on your PC.
