alex baker
30 points
Posted on - 01/29/2013
Hi experts,
I am using Visual Fox pro data my work. I want to convert Visual Fox pro into BDE. I am looking for converter software or any tool to do this. If you know vfp and bde and also its conversion, then please help me out.
Thank you
How to convert VFP into BDE?
Hello, converter software is available to convert visual fox pro into BDE.
You can find the software in ptf.com site. Software is compatible at win xp/vista/7 and 2.1 stable version is available now.Its advisable to use command if you are familiar  with windows dos commands.
There are so many site that provide solution to those DOS program.
