Convert .mp4 file to play on DVD Player
Asked By 210 points N/A Posted on -
I have NERO burner cd and i burn some music videos and save it onto a DVD tape. The process were completed but when i inserted to the DVD player the one burned from the computer, It says "Unsupport format" "Invalid Key" when i press play button.
Do you have an idea why the video cannot be played on DVD player?
I thought NERO is burner software?
Do you think it's the file format of the software? How can we convert video on MP4 file format that compatible to DVD player?
Apart from NERO what other software that can burn cd/DVD?
Thanks post your answers here.
Stephenee
Best Answer by Gary Monet
Answered By 0 points N/A #112134
Hi Stephenee,
What you are experiencing is compatibility error of your DVD player. There are some DVD players that can play certain file types of movies and such. There are also some players that could only play a few file formats of videos. Let me help you in choosing a converter so you can play your downloaded movies on your DVD player.
First of most DVD players have a common file format which it could read. Such as .avi and .mov, these files are common in most because it is the most commonly used file formats for videos. MP4, MKV, etc. are formats which are made into smaller sizes to fit into mobile phones, PDA’s, etc. Here are a few converters that you could try to help you watch your movies:
Pazara Free Video converter 1.4.
This video converter can convert MP4, MP4V files to AVI or MPEG .MP4 to .AVI, MP4 to MPG,     iPod MP4 to AVI.
  • It is also a user friendly program to which all you need to do is select the video which want to convert and select the type of video you want to convert it to.
  • It is also a portable program. It does not need any system registry to run the program. This means that you can run it in devices such as pen drives and removable drives.
  • It is also 100% free!
OJOsoft Total Video Converter.
  • This video converter can also convert movie files to pure audio. It has many features which can convert AVI, MP4, 3GP, MPEG, VOB, MOV, WMV, FLV and Audio. It also has vice versa effects.
  • It is a very simple program to use. All your need is to browse the file which you want to convert and click on which format you want to convert your video to.
  • One of the special features of this program is to select the speed of how it is going to convert your file.
  • There are two types of OJOsoft Total Video Converter you can get. The free type which can be used to convert all the stated types of files. The purchased type which gives you a wider variety of conversions and audio conversions and some extra features with guides on how to use the software.
ImTOO MP4 Converter
  • This video converter has many functions not only videos but also different types of audio. It can convert special file types like iPod, iPhone, Apple TV, PSP, PS3, Archos, Creative Zen and iRiver. These are uncommon file types which can only be used on those certain consoles.
  • The audio converter supports converting WMA, WAV, M4A, AAC, OGG, MP2, CDA, etc. to MP3, M4A and AAC audio, and extracting audio from video file. So if you have different players that couldn’t read the file type you can use this converter to convert the files.
  • There are also two types of imTOO MP4 Converter. The free one which can convert files to the common types of files such as AVI, MP4, MPEG, and MP3. The purchased one which allows you to convert any type of file to your desired type of file to be compatible to your player.
I hope that these converters will be able to help you solve your problem. Good luck and happy watching.
Answered By 5 points N/A #112135
Your DVD Player does not support your current format of videos.
Download Free Video Converter from here http://www.freemake.com/free_video_converter/.
Install it. And convert it to suitable format of your DVD Player.
Now burn all your video using Nero it will play with your DVD.
You no need to change your burn software.
