How To Convert VirtualBox To VMware? Explain.
I know how to convert VMware to VirtualBox but do not know how to convert VirtualBox to VMware. Someone, please tell me how to do this.
Converting VirtualBox to VMware is as easy as doing the vice-versa. First, open the VirtualBox application and select “export appliance” from the File menu.
Now, the export wizard will open. Over here, pick the VM that needs to be exported and click on “next”.
After this, select the destination folder and click on “save”. Now, click ‘next’ on the storage settings without changing anything. Then, click on “export” and the exporting process will start. Now open the VMware player and click on “open” from the file menu. Now, select the exported file and click on “import”. You have now successfully converted from VirtualBox to VMware.
