V Smith
20 points
Posted on - 07/27/2016
Hey everyone,
I have a created a Visio Document on MS Visio. I want to Convert Visio File to PDF using MS Visio 2007 without the help of any converter that I can find online. Someone, please provide me the steps for Conversion.
How To Convert Visio File To PDF Using MS Visio 2007?
There is no Conversion method available in MS Visio to change a Visio File to a PDF File. You have to download a Virtual Printer and install it on your machine. I will suggest you to download NovaPDF.
You can download it from www.novapdf.com.
After you install the Software, open the Visio File in MS Visio that you want to change. Choose the File menu, and click on Print. Select NovaPDF in the Printer’s Name, and click on the OK button.
