Hello people,
How to convert vob to real player? I need to convert at least 30 vob files into real player and it is kind a hard for me. Is there a licensed program that could possibly convert vob to real player? I will bring them during a travel to attend a seminar. I hope you can help me guys.
Thank you.
Make sure real player is installed in your device, if not download from http://client-software.real.com/free/windows/installer/stubinst/stub/rp16/R81APD/RealPlayer.exe and install it.
Open the realplayer app click on the logo. An arrow will appear, click on it and a drop down menu will appear. Click on File then click on "Scan The Disk For Media". Select the files you want to convert by checking the boxes next to their names.this adds them to the Realplayer Library.
Click on Next then on Finish. This opens the realplayer Library.
Click on "Converter" and drag all your files to the box.
Select the device/format you want to convert to and click on OK.
Press on the green start button and the converter does the rest.
