Hello guys,
I have so many files that need to be converted I need your help regarding this matter on how to convert wav to WMA Mac? Is there an application that will allow this kind of conversion? And if there are some please do let me know so that I will be able to start downloading it for free over the internet give me some tips to get a successful installation process.
Thank you.
How to convert wav to wma Mac?
This is exactly what you have been looking for: http://www.easywma.com/EasyWMA/About.html. This tool can easily convert a variety of different audio formats between one another. It’s having a very simple user interface so you do not have to study any additional tutorials to learn about conversion. Just choose your desired file, select the format to be converted into and hit start, that’s it.
There are many audio conversion software and I will list some good ones.
1. Switch Audio File Converter Software:
This converts and encodes sound files on PC and Mac. It supports all popular formats including wav, mp3, mid, wmv, deals and many others and can convert thousands of files at once. It can actually extract audio from any media file including video.
It works on windows 7, XP, Vista and Windows 8 all 64 bit versions. Also on Mac OS X 10.3 or above. A free version is available here http://www.nch.com.au/switch/switchsetup.exe, for windows find it at http://www.nch.com.au/components/switchsetup.exe, for Mac find it at http://www.nch.com.au/components/switchmaci.zip.
2. ISkysoft Video converter:
Another convertor. It's free for download. Find the Mac Version here http://download.iskysoft.com/cbs_down/video-converter-intel_full139.dmg and the Windows Version here http://download.iskysoft.com/cbs_down/video-converter-ultimate-win_full670.exe . It enables you to convert popular file formats like mp4, WAV, WMA .It's actually fast and can convert several files at once.
Happy testing.Â
