Jody Akerly
80 points
Posted on - 09/20/2012
Hello experts,
How to convert WAVÂ WMA Â windows mobile? There are so many converter in the internet I almost tried 3 but still it is not the right one or not working. Can you give me your suggestions it would be a great help for me.
Thanks
How to convert wav wma windows mobile?
To change in view of the 'Converter' located in the section 'Universal Converter'. Click in the button 'Files' and choose the option 'to Add files' in the menu desplegable.
Select the files that he (she) wants to turn. Now they will be added to the list in the sight of the 'Converter'. Like alternative, it can always drag and release files at sight.
Choose the profile with the format of the wished file of 'Turning'. The predetermined value is 'Universal, videos for the breeding animal of Windows It Comes up' that supports all the breeding animals of MP3, but other predefined profiles are also available, for example: WMA or AAC.
For thin adjustments or selecting a profile that is not preformed, simply click on the button with two arrows pointing up. Then it will see a menu that contains several formats like (as) M4A, WAV (to record on the disc), OGG and FLAC.
As soon as the exit (departure) format was formed, click on the button 'Start'. The progress will appear in the sight of the 'Converter', along with (near to) the files. The turned files will appear in the audio breeding animal in the right side of the screen after completing the conversion.
Now it can reproduce the files with Audio or drag and release them in another application or Explorer on Windows to export them.
Odom Vemus
