Hi Experts,
I am having apple macintosh OS on my pc.I need to convert waw to wma mac.Do you any convert supports mac os.I need to convert waw format to wma format .Two file types to be converted.Thanks.
Sharlene Ruby
How to convert waw to wma Mac?
HI there,Â
In order to solve this problem, I found a convertor that can be used on mac, and it`s free.
It should be simple to use, just like any other convertor that works on Windows XP or Windows 7.
https://software-download.name/video-converter-for-macos-sierra/
You have the link you can download from, and also a preview to help you do the job.
regards,Â
