Bryan James
30 points
Posted on - 12/01/2012
Hello fellows,
How to convert WinRAR protected to avi? I have some mp4 files zipped in a rar file and during the extraction it came up for about twelve mp4 files. I need them to be converted into avi files. Can you recommend a secure and reliable software to perform some conversion?
Bryan James.
How to convert winrar protected to avi?
If you want to convert a WinRAR protected to avi , you first have to break the password and extract it. You can break the password using dictionary attack or brute force attack. The 2nd One takes much longer time than the first. You can download related software from the internet. Once you extract the rar file you can use any video converter convert mp4 to avi. I suggest you to use “iWisoft Free Video Converter” to convert. It is very easy to use and you can convert to many formats if you want. You can easily download the software from the internet.
