How to convert .wk3 to Mac Excel ?
Hi All,
One of my friends has sent me a file with extension .wk3. I don’t know how to open it as I am using Mac OS X Leopard. Can anyone know about wk3 converter to mac excel ?
Hi All,
Hello Mr. Arnold,
Your first question about File extension wk3:
Wk3 is a lotus 1-2-3 version spreadsheet file that can open in lotus 123 software.
Second question: For the conversion, you have two options:
1.      Open the wk3 files in  Lotus 123 spreadsheet. Go to file-save as and select the file format as *. XLs.
2.      You need to install extension of  *.wk4. Open excel, Locate the Lotus 123 file, click open, go to file-save as & save the file as i said before.
Hope this would help you.
Thank you.
