How to convert wma to mov
If someone needs for converting WMV to MOV, so he absolutely want to know how to convert WMV to MOV.
Yes, sometimes we need to convert our WMV file to MOV. Actually, using software is the main way to convert video file like WMV to MOV. Also you can convert video directly through online.
I can give you the instruction how to convert WMV to MOV.
At first, download and install any of the video converter .
Then run it Find out add new or upload file.
Then select convert WMV to MOV and press convert now or start now.
That’s all. It is usually same for all the convertor. Now see the some important software below.
1. E.M. Total video converter
2. WinX
3. Oxelon media converter
For more details visit:
You can easily convert the files using a video converter. Here is the link for one such converter which converts the files online directly http://www.zamzar.com/convert/wmv-to-mov/
However if you want to use this type of software more extensively then i'd recommend downloading one or even better buying one. Here is the link for one such software http://osxdaily.com/2009/11/23/convert-wmv-to-mov-for-free/
Hope it helped thanks!
Hi Shakilbol!
You can convert WMV movie files to MOV format by using the FlipForMac;
You will need to do:
You can use this links;
https://video.online-convert.com/convert-to-mov
Thanks;
Notifications
