How To Convert Wmv To Mov On Pc In A Few Steps
Hi. I am a school student. I have a video with the extension WMV which needs to be converted to the MOV file format. How to convert WMV to MOV? Please reply ASAP. Thanks in advance.
Hi. To how to convert WMV to MOV, first download and install the correct version of the software Aiseesoft Video Converter for Mac on your PC. Next, import the WMV files by clicking on the add file option. Then, browse to the location where the file is present, select it and click on OK. Next, in the profile option, select the output format in which the file needs to be converted. Also, select the path where the converted file needs to be saved by clicking on the browse option. Towards the end, click on the Convert button and observe the progress bar for information.
You can also use the Movavi video converter. First, download the converter and after the download completes, double-click on the file and follow the steps for installing the software successfully. Then, click on the Add video option to import the files which need to be converted. Next, open the convert to list; go to video and audio and select WMV from the options given. Click on the convert option to begin the conversion. Wait till the conversion completes. Close the window.
Hope we helped.
