How to convert Word to PDF
I want to know how to convert a Word document to a PDF file for free. I’ve heard that some people are able to convert for free. I am using Word 2007. It will make my job easier if I would be able to find free software to do it because I will be using it all the time. I am excited to know your suggestions.
Best Answer by ralph.l
Answered By 0 points N/A #127201
Yes we can convert the Word files to PDF. This process can be done with the help of some software but when you try to convert the files in the free version you cannot convert many documents .
The free version allows only very limited access for conversion. If you can try searching for full version you will get enough to downloads there are many sites which has rights for download of full versions software.
In this site you can download a 14-day trial version. PDFTK, this software enables you to even split and merge PDF files
Answered By 0 points N/A #127202
You can use a tool to convert Word to PDF. Right now, I am using an online converter which is really useful for me as it can convert most on-demand file format. You can go to the link below and then choose the file you want to convert  and then select which format you would like to convert it.
Free Online File Converter
Answered By 0 points N/A #127203
If you are using Word 2007 or above, you could directly save as PDF format. But please note, you need to firstly install an Microsoft add-in to do this if you are using Word 2007.
But as we all know, the Word is not so professional on PDF converter, you could use some great PDF converter service to do your job.
1. Free online service like Zamzar â€“ Very great website to convert the files online.
2. Desktop PDF converter like Nemo PDF converter from this link With the batch convert and partial convert, you could make the conversion job easier.
