How To Convert Wps File To Word Using Some Simple Steps
Hi. I need to submit a file converted from WPS to Word as part of my computer science homework. How to convert WPS file to Word? Please help me with the same? Thanks in advance.
Hi. To know how to convert WPS file to Word, first open MS-Word and open the blank document. Click on the window icon and then click on the open option. Next, browse the .WPS file which needs to be converted and click on open. After the file opens, click on the save as option and then click on word document from the options which appear. To open all the .WPS files in Word by default, double-click on the file and then click on select the program from a list option. From the options which appear, select MS-Word. Ensure that this file is used to open these file always. Select OK.
You can follow another simple method for the conversion. Download the software MS Works 6-9 file converter and install it by following the instructions displayed. After the installation completes, open the .WPS file by double-clicking on it. From the list of installed programs, select a program and then click on OK. Click on MS-Word from the open with dialog box. Click on OK.
Hope we helped.
