How to convert xls to txt Mac?
Hi Guys,
I would just like to know if how to convert xls to txt mac? A software that can be downloaded over the internet that will allow this to be performed.
Thank you.
Hi Guys,
Thank you.
There are several converters available for Mac to convert xls to txt. After a quick research I found some websites where you can download the software. Click on the below link to download xls to txt converter for mac. http://www.softpedia.com/hubs/Convert-XLS-to-TXT
There are several other software’s available but above software is the best for you.
Thank you.
Hello, Dudley Achan!
You are right. We can do it with a software called Convert XLS 6.61. It's very popular. Moreover, you can get more software by searching online. Softpedia provides this software totally free for you.
You can download it from this link
http://file.software.informer.com/download-file-conversion-xls-to-txt-mac.
After downloading, just follow the instructions. You can do it. It’s really very easy. Enjoy it!
You don’t need to actually download a program to convert Office Excel files (*.xls) to plain text (*.txt) on your Mac. If you only have a few files to convert, you can easily do it within Microsoft Office Excel. It’s as easy as doing a Save As. You can save it in “Text (Tab delimited) (*.txt)” or “Unicode Text (*.txt)”.
To do this, start Microsoft Office Excel then load the Office Excel file. Next, click File or the Office button then select Save As. An alternative is to press F12 on your keyboard.
After this, in “Save as type”, select “Text (Tab delimited) (*.txt)” and click Save.
The saved text file can be opened in Notepad or any applications that support text files. The text file should look something like the image below.
