How to convert XML multiple choice questions to an Excel file?
Hi guys,
Please help me convert an XML multiple choice questions to other file formats such as Excel. Is that even possible?
Merci.
Hi guys,
Merci.
Many people say that it is a long process to convert an xml file to an excel file. It is very easy to convert xml to xls format. Follow the steps below:
1. Run Microsoft Excel on your computer and wait for it to load.
2. Now, click on the file tab and click "Open". By default, Microsoft excel shows the excel files in your computer in the open window.
3. Change the type of file to xml by selecting XML files in the drop down menu of the file type option.
4. Now, you will see the xml files on your computer. Select the file you want to convert and click open.
5. The xml file will now be converted to excel file.
Hope this information helps you.
The easiest and most convenient way of converting .xml files to .xls or .xlsx format is already explained above. That’s the best way without purchasing any XML conversion software. But if you want a paid software that is solely dedicated on converting .xml files to Microsoft Office Excel format, then here are several you can use:
