How To Convert XPS To PDF
Hi. I am a student currently in standard twelve. I want to know how to convert XPS to PDF. Please suggest me some simple steps how to go about doing it? Please reply ASAP. Thanks in advance.
Hi. To learn how to convert XPS to PDF using Internet Explorer, first open the IE browser and click on gear then file and then open. After this, select the XPS file which needs to be converted to PDF. After the file opens, right-click on the page of your choice and click on the print option. Then, select the novaPDF option from under the select printer section and then click on Print. Select the location where the file needs to be saved and then click on OK.
Alternatively, you can also use a XPS viewer by opening the XPS viewer. Then, click on file and then open. Open file and select the print option. From under the select printer section, click on novaPDF. The PDF can be customized too by selecting the Preferences option. Then, browse the location where the PDF needs to be saved and finally click on the Print option.
Hope we helped.
If you need to convert an XPS file to PDF format, the easiest way is to convert it online. You can convert your file without installing any application. To begin, go to Online PDF Converter. Here, upload your XPS file. You can upload the file in four ways: from your hard drive, via URL, Dropbox, and Google Drive. Once the file is uploaded, configure the conversion settings.
Click “Start conversion” to begin the conversion. Once the conversion is complete, you can download the file instantly. Another service that offers XPS conversion to PDF is XPS to PDF. Just upload the file and convert. You can also download the file immediately after the conversion.
