Hello experts,
How to convert the xsd to xslt? Share some suggestions or advice on what is the best software for converting the xsd to xslt files. I have 50 files to be converted immediately I need a software that will help me to make things done, thanks.
To convert XSD files to XSLT format, you can use Atova's XMLSpy. Download XMLSpy https://www.altova.com/download . Install and Run XMLSpy. You will be needing an evaluation key to use this software.
So click on Free Evaluation key, fill out the form that will come out next, then click on Request now. Log on to the email address that you used to receive the keycode that Altova will send to you. Input the code then click Ok. On XMLSpy go to File > Open. Browse for the file you want to convert then click Open, go to File again but now click Save as, choose XSLT as the output format then click Save.
