Hello fellows,
How to perform std file conversion? My current operating system is Mac, the company bought a computer with this built in operating system. I am an administrator for our company website and they are expecting me to do technical stuffs such as encoding, networking, troubleshooting, converting files and more. Can share some idea about std file converters? Thank you.
Ericson Eric.
How to converting STD file with Mac?
You should download "The GNU Image Manipulation Program" (GIMP 2.6.6.). Then install it into your pc. Opening the software you should click on load button and select the item that you want to convert and select save as and save the as a file format that you wanted. It would be hopeful to solve your problem.
Hello Ericson Eric,
Please elaborate more on what std is. As what I have seen, std could stand for an image file which can be converted to any image using an image converter software. It could also mean an OpenOffice.org drawing template. Also you didn't specify as to what to convert into. Please elaborate on this more so we can help.
Hope this helps.
