rubiagguire
Posted on - 02/01/2012
I have hundreds of pages of PDF file, I took many notes all with upad. I now need to transfer this file to my computer. When I open itunes it is not listed under File Sharing > Apps > Upad. (I use upad lite). I’m unsure if exporting PDF back to a PC is only an available feature to the full version? How would I get PDF’s back onto my PC.
How to copy PDF files from Upad to my PC
I think that it requires a full version to do this. Because this is very slight chance that your itunes is corrupted or you have any problem in your ipad. I also own an ipad 2 and for handling all types of pdf files i use Adobe reader and Documents. They both appear under the file sharing in the apps tab.
Also before going for the full version, make sure that you select the export option on the main file and not the file which is converted to email someone or is a backup to that file.
Also download the latest version too. They have fixed few bugs in it so there is a chance that this error gets removed too if you update it.
