How To Copy A PDF Into Powerpoint Step-Wise
Hi. I have prepared a PDF file and I want to enter it into my PowerPoint presentation. How to copy a PDF into PowerPoint? Please reply ASAP. Thanks in advance.
Hi. To learn how to copy a PDF into PowerPoint, first open the PDF file in Adobe. Then, in the tools menu, click on the basic menu and click on select. Then, from the PDF file, copy all the text that is to be copied. From the edit menu, click on select all option to select the contents of the file. Then click on the copy option from the edit menu. Then, open MS-PowerPoint and then click the location where you need to paste the text. Click on the paste option from the home menu.
Alternatively,
Open the PDF which needs to be inserted. Click on the insert tab. Then, click on object. From the insert object box, select the Adobe document option. Click on OK. Then, after selecting the PDF file which is to be inserted, click on OK to open the file. After this, the entire document will appear on the selected side.
Hope we helped.
