Mia Molly
20 points
Posted on - 10/19/2012
Hello experts,
How to copy status from msn? When I tried to access my MSN live messenger and tried to copy all my previous status posts or message status from my friends there is a problem occurred and it says unable to copy. Why is this happening? Give me some brief explanation.
Thank you.
You can copy your status from msn. to do that you have to go to the start button, all programs, accessories, system tools and character map. All texts and symbols are available in the Character Map. Copy the symbols which you want and open a notepad and paste it here and rename it with the name which you want then paste it in your MSN status.Â
Hello Mia,
To copy your status from MSN. Highlight the status first using the mouse or press the SHIFT+ right arrow (–>) using keyboard and then press Ctrl+C to copy and paste the text into where ever you want to use Ctrl+V. Sometimes the Browser or messengers do not allow to copy using a mouse due to certain restrictions. Always copy and paste using hot keys.
Thanks
It is very easy to copy your posts, status or messages from any messenger even from msn. You may have to go to your account and then go to messages history or your status. Now keep your cursor to the point from where you want to copy then press shift key and then press your cursor to the end point till you want to copy your post or status.
Now you have two options to copy your post or status.
Press Ctrl + C key
Right Click your mouse and you will see new menu please select copy button.
By using any of the above methods you can easily copy your posts, status or messages.
