How to copy/export Inpage (urdu) text for Adobe Photoshop
Hi.
I am working on a website which has Urdu language text written in inpage format ,that is all nice looking edited text. I have to export it to Adobe Photoshop to ad in the image of website. I tried to copy and paste but failed. Please let me know if you have any idea to do solve my problem. Quick reply will be helpful
Answered By 0 points N/A #125987
First, open a file in Inpage and use the Write Text function to write down. Set the page to A5 and all the margins to zero. To write the characters, go to Edit>Preferences>Keyboard Preferences, then choose Phoenetic. Select your textbox and Save. From the File menu, select Export Page. You may key in the file name or browse for it. Now you can open it in Photoshop and paste it in any background that you like. Open the picture that you need or set a template that you would use. Then open the Inpage file and you will now be able to copy and paste it using Photoshop. Make sure to save your files with extensions that is compatible to Photoshop.
