Enterprise Architect has got a very good integration with Eclipse, but there are other tools out there that you could still use.
Nicke
I can't import the StarUML file to EMF to begin transformation. Does anybody know how correctly import UML XMI files to Eclipse (EMF)?
Hello Adams,
If you can successfully export your UML model into XMI from StarUML, then it is possible for you to import your model into Enterprise Architect.
Nicke
Notifications
