How could I automatically release connections in Websense 6.1?
I have Email Security Websense 6.1 and very fast reach the limit of 1,500 active connections of the “Receive Service”. What shall I do so that connections are released automatically as not to get to this limit?
Answered By 75 points N/A #98307
Hello Deepak Hans,
If you need to reduce the speed at which your email security websense application is working with the receive service to a lower number than the current 1500 connections in an instance then you will need to do that from the applications settings,
Just open the applications and then access its settings, and under the settings look for the option for reducing the connections at an instance and then reduce the connection speed from 1500 to a lower number that you want. Therefore you should be able to use the receive service at a much slower speed.
Hope this helps.
__
Regards
Lee Hung
