Hi to everyone. I have some files in PDF format and now convert into MS Word but whenever I try to convert some pdf to word format, appearance and text style disturb in Converted MS word file and it seems very hard to set all formats and layout again. I have tried many software available on the internet but none of them is covering this problem. Anyway some difference occurs at conversion. Please show some guidance.
How to cover formatting problem while converting some pdf to word documents?
Hello Dear,
There are many software that can convert your pdf files to Microsoft word files with the same format.
Some software are available that make the problems while converting the pdf files to Microsoft Word files. The problem which encounters is only relating to formatting.
The source PDF file has the format correct but in word file the format is totally changed and you need to reformat it.
Now I am going to suggest you a software that will remove this problem.
You should use Nitro Pdf editor.
This will remove the problem of reformatting.
Download Link
Click the above link to download Nitro software.
Thanks
