How to create 2d lighting designs?
Hello experts,
How to create 2d lighting designs? Also share with me the best software to use when creating 2d lighting designs and any tutorials will do so that I will be able to learn from it and create my own 2d designs? Your help will be much appreciated.
Thank you.
Best Answer by Amanda Angel
Answered By 10 points N/A #186458
Vectorworks Spotlight is the best way to create different attractive and beautiful designs; it has all the tools necessary for effective designing. It is also really very important to have great software installed so that you may work rapidly, for this, Straw Lighting 2D 2007 is the best software because it makes lots of easy things for you during the designing procedure.
Answered By 0 points N/A #186460
Hi Benjamin,
I would recommend Microlux for creating 2D lighting designs if Vectorworks Spotlight is too expensive for you. Microlux is a good, easy to use and less expensive application for creating 2D and 3D designs. You can try it out for free from their site.
They also have tutorials that you can use. Here’s the link if you’re interested Microlux.
Hope this helps you.
