How to create 3 arrays using JAVA input?help
Hi everyone, I'm really new to programming and design and I'm still in the perfect learning process though I know HTML5 but Java is where I lack knowledge little bit, so friends please guide me I want to create 3 arrays using Java input. Is it possible to create 3 arrays at once that is
Array[]1,array 2[], array3[]
Please correct me if I'm wrong.
Answered By points N/A #184749
Every single programming language includes the feature of “Array” as it gives tremendous power to the developer to make his programs more cunningly.
The technique you’re trying to apply is multidimensional array. It’s quite possible to use such type of array on Java, too.
Here’s a complete guide on using multidimensional array on Java. There is also a good explanation on Java array on this page.
The type you're trying to do, in my sense, is incorrect. The correct sequence will be array[][][].
