How To Create Access Database For Finding The Answer To The Query?
Access database helps us to display answers to the questions and queries. You can modify records in the database. How to create access database?
Access database helps us to show the answers to the questions and queries.
You can make changes in the records in the database such as you can add, delete and do many things with multiple files at the same time.
Step 1: Open your database after starting Microsoft Word.
Step 2: Click on the Queries then New button then Design View. Now you can create a query.
Step 3: Select other queries such as tables as well as choose the category or field.
Step 4: You can check the result of the query by running it.
Step 5: You will find a Query type option in the middle of the screen. Mention the type of the query.
Step 6: Change to Make- Table. After you create the new table, give it a name.
Step 7: Run your query and then Save it.
