G Racho
Posted on - 08/20/2016
I am an employer. I need to send the same email to many employees at the same time. Instead of sending it individually I want to create a mailing list. How to create an address list in Excel?
How To Create An Address List In Excel By Following The Steps?
You can create an address list in Excel. It will help in removal of the problem of sending an email individually to many people. You can create a mailing list.
Step 1: In the first row, enter the name of the data labels after opening Excel.
Step 2: Type the list of customers or you can also paste it.
Step 3: Open Microsoft Word after saving the mailing list.
Step 4: Select Mailings Menu then Start Mail Merge and choose Step by Step Mail Merge Wizard.
Step 5: Choose the way in which you want to print your mailing list and then press Next.
Step 6: Go to Labels option and then select one of the options.
Step 7: Click on Browse and find your mailing list after choosing Select Recipients.
Step 8: Select Table window will appear, press OK.
