How To Create An Adobe Fillable Form Through Different Ways?
Sometimes we need to fill documents through the Web, especially in the official work. Also, we need to fill PDFs in this process. How to create an Adobe fillable form?
Method 1- Creation of a Fillable PDF.
Step 1: You need Adobe Acrobat that is useful in filling the PDFs.
Step 2: You need to download and install it.
Step 3: Select Tools and then Prepare Form and then Open.
Step 4: You will get two options. One is Select a file, and other is Scan a document. Choose one out of the two.
Step 5: Convert any file into a fillable file by selecting it.
Step 6: Finally click Start, so that Acrobat will add interactive fillable form fields.
Method 2- To add or delete the Fields.
Step 1: For removing a field, select it and then press Delete key on your keyboard.
Step 2: For adding a new field, choose an option of Add New Field.
Step 3: Place your cursor to add it and you can also click and drag to adjust the size.
Step 4: There will be a yellow tooltip box, enter the name of the new field. There will be an option of All Properties; you can click it to customize the field.
Step 5: Use editing tools and then you can view the document by clicking the option of Preview. Finally, save it.
Notifications
