How to create a advanced JavaScript digital timer?
I am good at HTML and CSS but not good at JavaScript. I want learn about an advanced JavaScript digital timer. Do you have a clear tutorial and explanation over it? I appreciate your help.
Hello there Lenore,
I know you are having a hard time in learning JavaScript, but I tell you it is just easy as HTML developing. With regard to your problem, I hope this two tutorials could help you achieve what you want. The first tutorial and another tutorial.
Hope this helps you.
Regards, Roland.
You may want to refer to tutorial websites such as Lynda.com for you to learn basic to advance Java script writing. There are also documentations on theJava website WWW.JAVA.COM, if you want to know more about the technicalities of what you want to learn. There are also other websites where you can test javascript.
