How to create advanced login script vbs.
10 points
Posted on - 10/20/2012
Hello experts,
How to create advanced login script vbs. I am using visual basic script for my log in form in vb, but suddenly there is some problem about the coding. Can you give me some example codes for log in information? Even just a little information or coding instruction will do. Thank you.
