Halton Roy
50 points
Posted on - 02/27/2013
I am a new SEO developer . I need to optimize my web site by advertising traffic spreadsheet with a high traffic keywords . But I don't know from whom I have to start . Please help me anyone by showing the easiest way . Advance thanks .
How to create advertising traffic spreadsheet ?
Hi Halton Ray,
Make sure to make a high traffic keyword and but a lesser bounce rate, this means that you need to use a keyword that is relevant to your page. Check your keywords by using spreadsheet programs such as google doc or Microsoft excel.
There are several techniques you can use for keyword optimization. One of them is the Whitehall technique, also called an ethical SEO. Your keyword and/or website page rank will depend on the frequency of the activity on your website, and on how it is being optimized. You may also want to check your keyword/s first against other possible keywords you could use, using programs that help you analyze keywords. This may also help generate traffic on your website. Try visiting this site: http://www1.bibianowenceslao.com/?.
Best of luck!
