Ericson Eric 10 points N/APosted on - 11/05/2012
Hi to everyone,
How to create after effects realistic sun? Adobe after effects helps me a lot on creating and adding motion graphics effects and really satisfies the user’s need. I would like to ask some help to those adobe after effects experts, suggestions and ideas on how to create realistic sun.
I will give you a YouTube video tutorial link. If you watch this tutorial, you will be able create realistic after-effects. The tutorial link is below.
So, if you see this video, you will find your solution.
Hi Ericson,
The Photoshop is used to create effects of realistic sun.
The steps to create the effect are as follows:
1) Open the image and add the gradient fill layer
2) Click 'Gradient' option and select the foreground and background color
3) Set the gradient layer bend mode to color and set the curves adjustments for the image
4) Create a new layer between the curves adjustment and the gradient fill
5) Set the values of the foreground and background color for the image
6) Set the blend mode to soft light and lower its opacity
7) After the settings are completed, you can see the effects on the image
A Quiet Revolution in the World of Pages
Once upon a time every book left a trail. Bent spines dust jackets that never quite sat right paperbacks split at the seams. Shelves groaned under the...
1....
