How to create and customize Magento new order email?
Hello. I am using Magento hosting and i want to also use it for new order emails. I'd like to ask what are the steps done on creating Magento new order email and can it be customized?
Hi Coury,
I understand you are looking for a way to Customize your Magento new order email. It can be very difficult for a first timer if you don't know how to go about it. However, it is as simple as ABC. There are some steps by steps procedures that are often overlooked when customizing Magento new email order. You may follow the links below to learn how to customize your Magento:
http://www.beperpetual.com/2009/11/customize-magento-system-email.html
https://magento.stackexchange.com/questions/114107/how-to-customized-the-new-order-template-magento
I hope I have helped you.
Notifications
