I am a Mac OS X user. After installing OS X, I get a catastrophic hard-drive crash that requires me to initialize or replace my boot drive. The event selection didn't appear in proper place for lion calendar task. Can anyone help me how I will create and manage lion calendar task on Mac OS X?
How to create and manage lion calendar task on Mac OS X?
Hi there Goldman,
Creating task/event on Calendar (OS X 10.8 or higher)/iCal (OS X 10.5 below). Here's a tutorial for you can create a reminder or a task on iCal/Calendar on mac:
Go to Apple Icon > Select File -> New Reminder > Enter the desired information in the Title field. example : "My Birthday"
On your keyboard press CMD-K and enter the desired information in the Title field.
Double-click on the new reminder (or press CMD-I) to open the Info window for the reminder and modify as appropriate. Note especially the Listoption, using which you can specify which Reminder List the reminder belongs too.
You can see the full tutorial at Wisc Edu's Helpdesk
Hope this helps you.
Waall Mike
Hi Goldman,
I am giving you information below.
• Choose a File ïƒ New event, Press Command + N, double click , or click and drag up or down anywhere on the calendar.
• If the event does not appear in the proper place, just click it and drag it wherever you like.
• To edit an event, Select it and then choose Edit ïƒ Event, Press Command + E, or double click it to open its event bubble.
• When you are satisfied with all of the events items, click the Done Button. Hopefully this information will help you.
Thanks,
Raun Nelson
