How to create apple organization chart?
Hi everyone,
How to create apple organization chart? And what is all about an apple organization chart? Kindly tell me the difference between an apple charts to other kind of charts such as ERD and data structure data. I hope you can provide the best information.
Best Answer by Bankk benediict
Answered By 0 points N/A #186536
There is no big difference as long as any chart is understandable these types of charts or ERD can be drawn by Mysql Workbench and thought that it can be even converted into a script. For apple they have done a specific way to understand or do it. The image given below shows that
Answered By 5 points N/A #186537
Dear Benjamin,
Draw Entity Relationship Diagram (ERD) it is a diagram that represents the structure of a database and show the relation between its components in an easy understandable shapes. There are much software doing these diagrams but I recommend using this tool called visual paradigm ULM, you can find a trial version of the program and complete tutorial on the link below.
https://www.visual-paradigm.com/tutorials/how-to-model-relational-database-with-erd.jsp
Answered By 0 points N/A #186538
There’s no difference between an Apple chart and any other charts, they are pretty much the same. Apple Pages allow the construction of advanced page layouts besides advanced word processing. While the layout tools are used to create different shapes for different generations in the chart, the style controls are used to adjust color of the shapes, line styles, font, size and color for the text, etc.
A simple tip before getting started is to make up a planning with pencil and paper and make sure you have considered all the stakeholders.
