Hi Experts,
I am currently engaged in ATM application development. I need  advice on  ATM interface application java. Does anyone know how to archive this. I am developing this application using java. I tried to add buttons but could write appropriate coding. Provide me instructions. Thanks.
Halleleilani
How to create atm interface application java ?
Hello Halleleilani,
The best way to design Java UI app is using an IDE like Netbeans. If you want to directly code the interface then you should be using java swing. There are tutorials on how to use java swing. For the quickest option you should be using Netbeans.
we want to develop atm interfaces for our project. what is the best software to use? IDEs or Java Swing?
