How to create atm Machine in pascal coding?
Hello Experts,
How to create ATM machine in Pascal coding? I know an ATM machine codes are so hard to understand and figure it out using a Pascal coding technique but I just want to know some related ATM machine software program as a basis to create my own small ATM machine as a project. I hope you can give me some sample codes or any tutorial to get this done.
Thank you.
Best Answer by Kaile Smith
Answered By 0 points N/A #184813
Hello Timothy Raine,
The best ATM machine Pascal coding can be found at the free download manager website. Right now, click the link below:
Then, go to the bottom of the page, there you will see download, just click that and you will find your desired items.
http://www.freedownloadmanager.org/download/atm-machine-in-pascal-coding-5335179.html
On this page, you will find a lot of software for ATM machines in Pascal coding.
Answered By 0 points N/A #184814
Hi Timothy!
To learn how to create ATM machine in Pascal code, you must first download or install shareware who can perform the coding. It is a process to come up with the coding. Here is the link where you can have a free download because there are other shareware which can perform faster and safe but it is for sale.
http://www.cfbsoftware.com/cpide/cpide.aspx
When you precede to this link you will learn the procedures and other discussions about it.
Thank You!
Answered By 5 points N/A #184816
Hi
Here is the code that my friend was used, in their project. Read it and understand the logic behind it.
procedure consulter;
var archivo:text;
begin
textbackground(green);
clrscr;
writeln('ÉÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍ…
writeln('º BIENVENIDO A SU BANCO UNIVERSITARIO º');
writeln('ÌÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍ…
writeln('º DETALLE DE CUENTA º');
writeln('ÌÍÍÍÍÍÍÍÍÍÍÍËÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍ…
writeln('º NOMBRE: º º');
writeln('ÌÍÍÍÍÍÍÍÍÍÍÍÎÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍ…
writeln('º CUENTA: º º');
writeln('º SALDO: º º');
writeln('ÈÍÍÍÍÍÍÍÍÍÍÍÊÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍ…
writeln('***************GRACIAS POR PREFERIRNOS***************');
writeln;
assign(archivo,'C:Bancouniversitarioda…
reset(archivo);
while not(eof(archivo)) do
begin
readln(archivo,id);
readln(archivo,nombre);
gotoxy(16,6);writeln(id);
gotoxy(16,8);writeln(nombre);
gotoxy(16,10);writeln(saldo);
end;
writeln;
writeln(' Presione cualquier tecla para continuar');
writeln;
writeln('********** ES UN GUSTO SERVIRLE **********');
close(archivo);
readkey;
end;
I hope it will help you a lot.
