Kaylie Jane
30 points
Posted on - 03/22/2013
Hello experts, I am an Executive manager and I am familiar with IT. My boss gave me the job about create attendance list for meetings. So I need to do it properly and as soon as possible. I need to create attendance list without using MS Excel. Please tell me what the best way to create the list. Thanks.
How to create attendance list without using Excel
Hello Jane
That is so simple, if you don't want to use excel i would advise you to use ms word by following this directions.
probably you do not need to make any fresh installations since you already have ms excel then it means that you also have ms word. so just go ahead and open office word – insert Table and choose the number of columns and rows then start capturing the attendance list. you will find it easy.
Alternatively you should also try out ms access by creating a simple database containing the variables that you need to capture, this will simplify you work electronically.
Hope this helps you
Thank you
Shardrack
