How to create auto ghost cd using a suite
Please assist on how to create auto ghost cd using a Symantec Ghost Solution Suite 2.5. Not sure about the steps, please take me through.
Here are some basic steps.
> Make a basic boot CD, Make sure WinPE is highlighted.
> Fill in the user name/password/domain
> Map a drive to a server that you can put the image up to.
> Boot from the CD
> Click Local, Disk, To Image.
> Go to the mapped drive and save it.
If you do not see the mapped drivejust exit ghost and in the WinPE command prompts,
> Type IP config to see
If you have an IP address, you will need to add the drivers.
> On another PC of the same make/model: Boot from the disk and pull the image down, Local, Disk, From Image.
The PC name will be the same, but at least you know it worked.
> Now make a new boot CD.
This time on the 3rd screen
"Client Type" put in the parameters "src=" to your mapped drive and name of the ghost image.
Boot from the CD on the test computer again and make sure it clones the computer by it's self.
Hope to enjoy it.
Thanking you
Franke Mary
Notifications
